EcoFlow DELTA 3 1500 Portable Power Station | EcoFlow CA - DELTA 3 1500 + NextGen 220W Solar Panel
EcoFlow CA
EcoFlow DELTA 3 1500 Portable Power Station + NextGen 220W Solar Panel
$1,649.00 CAD
Regular price $1,649.00 CAD
Sale price $1,649.00 CAD Regular price $2,148.00
-$499
$1,649 CAD $2,148 -$499
EcoFlow DELTA 3 (1500) Portable Power Station
Keep appliances running day-to-day and through emergencies
1.5kWh-5.5kWh expandable capacity
DELTA 3 (1500) offers a large 1536Wh battery capacity, expandable up to 5500Wh. Keep your appliances running, for everyday use or as home backup. It's flexible and on-demand energy.
You'll always be prepared with never-before-seen fast charging
5 industry-leading charging methods
AC outlets
Solar energy
Car charging
Generator charging
Multiple inputs
With EcoFlow's 1500W X-Stream AC input, DELTA 3 (1500) charges from 0-100% in only 90 minutes. Stay prepped for a power outage or take a last-minute camping trip.
Utilize the sun's energy with a huge solar input of up to 500W. Fully charge DELTA 3 (1500) in as fast as 3.5 hours with EcoFlow Portable Solar Panels.
Using an 800W Alternator Charger, it takes just 2 hours to fully charge, 8× faster than other methods. Charge on the road, so you don't need to prep in advance.
Fully charge DELTA 3 (1500) in only 1.5 hours. The EcoFlow Smart Generator 3000 (Dual Fuel) automatically replenishes power at night, ensuring constant backup without getting hands-on. [
With an input of up to 1500W, it takes only 90 minutes to fully charge DELTA 3 (1500) using both AC and solar, prioritizing sun power to save money.
Power 99% appliances without overloading
1800W output (3600W surge) with up to 2200W X-Boost
EcoFlow DELTA 3 (1500) can power 99% of household appliances, including refrigerators, TVs, and computers. With X-Boost, continuously run high-power appliances up to 2400W, from ovens (2150W) to hair dryers (1800-2500W).
Home backup
Outdoors
RV
Professional work
Long-lasting and durable, ensuring constant and reliable backup
Triple protection for guaranteed safety from the inside out
LFP battery
IP65-rated
BMS
IP54-rated for resistance against water splashes, dust, and smoke, ensuring durability in various environments. Protects against harsh conditions, providing long-lasting performance.
UPS for home backup
15 ms auto-switch to battery power
Constantly run your refrigerator, fish tank, or CPAP in case of emergencies. Keeps your home essentials powered up no matter what.
Powerful yet lightweight, take power anywhere
36.3 lb & 15.7 × 8.3 × 11.1 in
Power home appliances, outdoor activities, or DIY. Easily lift up and take it anywhere.
Footnote:
All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment and actual user experience may vary.
3. The input and output wattage of the Smart Extra Battery will decrease to 100W when ambient temperature is higher than 95°F (35°C).
4. The IP54 water-resistance rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
Select your language
{"statementLink":"","footerHtml":"","hideMobile":false,"hideTrigger":false,"disableBgProcess":false,"language":"en","position":"left","leadColor":"#146ff8","triggerColor":"#146ff8","triggerRadius":"50%","triggerPositionX":"right","triggerPositionY":"bottom","triggerIcon":"people","triggerSize":"medium","triggerOffsetX":20,"triggerOffsetY":20,"mobile":{"triggerSize":"small","triggerPositionX":"right","triggerPositionY":"bottom","triggerOffsetX":10,"triggerOffsetY":10,"triggerRadius":"50%"}}
