EcoFlow DELTA 2 Max Portable Power Station - EcoFlow CA - DELTA 2 Max + Extra Battery + 160W
EcoFlow DELTA 2 Max + Extra Battery + 160W Solar Panel - Web Exclusive
$2,599.00 CAD
Regular price $2,599.00 CAD
Sale price $2,599.00 CAD Regular price $4,697.00
-$2,098
⚡️ 48Hrs Flash Sale Ends in
Days
Hours
Minutes
Seconds
  • 2-Day Delivery
Order DELTA 2 Max Portable Power Station by 7 AM (PST) for delivery within 2 business days across select regions of British Columbia & Ontario.
Learn more
Free Shipping Policy
Free Shipping to Canada except Northwest Territories, Nunavut, and Yukon.
2-Day Delivery
2-Day Delivery Regions
British Columbia
: Coquitlam, Richmond, Victoria, Duncan.
Ontario: North York, Toronto, Ajax, Oakville, Waterloo, Newmarket, Peterborough, Richmond Hill, Etobicoke, Fenelon Falls, Campbellford, Meaford, Green Valley.
• Expandable capacity - 2-6kWh expandable capacity with the DELTA 2 Max Smart Extra Battery to meet your energy needs—ideal for RVing, outdoor use, home backup or daily power.
• Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output - With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
• Fastest recharging - World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
• Capture more energy - 99% MPPT efficiency maximizes solar generation anytime.
• Customized in-app energy management - Prioritize solar or AC charging, view input and output power, battery levels and more.
• 5-Year warranty
$429 CAD $899 CAD
25% Conversion Rate | IP68
$899 CAD $1,699 CAD
$469 CAD $699 CAD
Subscribe DELTA 2 Max for latest updates
$2,599 CAD $4,697 -$2,098
Ultimate Power for Life Outdoors
Expandable up to 6kWh
Enjoy more power for group trips, extended adventures, or emergency backup—all from one modular system.
Built for Every Scenario
Power up your RV life, outdoor adventures, and home backup
RVing & Outdoors
Home Backup
DIY Projects
Filmmaking & Photography
*Note: Runtime is based on powering a single appliance. All test results shown are based on intemal testing and may vary depending on usage conditions.
4 ways of industry-leading fast charging
Car Charging
AC Input
AC + Solar Dual Charging
10 Years of Reliable Power
Reliable energy for daily life, built to power you for over a decade.
Smart Power Control at One Click
Anywhere. Anytime. Have full control of your DELTA 2 Max with the EcoFlow app.
Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Stay worry-free during blackouts. AC Always On Mode keeps your power button active throughout outages and recovery, so your appliances stay on without interruption.
Customize AC or solar input for backup power or energy savings. Prioritize solar energy via the EcoFlow app when using X-Stream AC + solar dual charging.
Always ready for power. Get notified via the app when the battery is low.
Extensive 5-Year Warranty
Why choose EcoFlow DELTA 2 Max
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
User manual & warranty card
2048Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3400 W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 1800W, 15A
AC Input Voltage
100-120V~ max. 15A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
EcoFlow WAVE& WAVE 2 & GACIER &Smart generator
Supported
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23kg
Select your language
