EcoFlow Alternator Charger XT60 Output Cable (1m) - Default Title
Regular price $79.00 CAD
Sale price $79.00 CAD Regular price $79.00
-$0
Compatibility
The cable is compatible with EcoFlow or third-party portable power stations equipped with an XT60 input port.
If your vehicle starter battery or RV house battery operates at 24V, ensure the maximum voltage rating of the power station's XT60 input port exceeds 48V. Otherwise, the cable may not function properly.
Connection
Use the cable to connect the Portable Power Station Port of the charger with the XT60 input port of the power station.
Operation
With this cable, the charger only supports Charge Mode and offers a maximum output power of 500W (subject to the ratings of the XT60 input port).
$79 CAD
⚠️ Firmware Update Required for 1T2 Accessory
To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
Required firmware versions:
  • DELTA 3 Max Plus: v7.80.98.44 or above
  • DELTA 3 Ultra Plus: v7.80.98.46 or above
If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
Thanks for sharing!
Select your language
