EcoFlow 130W RVMax Rigid Solar Panel - 2*130W RVMax Rigid Solar Panel
EcoFlow 130W RVMax Rigid Solar Panel EcoFlow 130W RVMax Rigid Solar Panel EcoFlow 130W RVMax Rigid Solar Panel EcoFlow 130W RVMax Rigid Solar Panel EcoFlow 130W RVMax Rigid Solar Panel
$579.00 CAD
Regular price $579.00 CAD
Sale price $579.00 CAD Regular price $699.00
-$120
  •  Perfectly tailored for RV use, size suitable for various RV types
  • 0.5 in (12 mm) ultra-thin panel effectively reduces 60% of driving wind resistance Connect up to 10 panels in parallel (1300W)
  • NEW LFB-40 port with enhanced stability - stays firmly connected even during movement
  • Up to 25% conversion efficiency rate
  • TOPCon solar cells perform well in low light and high temperatures
  • Up to 5-year warranty and 30-year lifespan
Accessories
$579 CAD $699 -$120
Perfectly Tailored for RV Use
Aerodynamic Solar Solution That Fits Any RV Roof
With a 30-year lifespan, this durable, low-maintenance solar panel is ideal for RV use.
Size fits various RV types:
The narrow, rectangular design fully utilizes the roof space of almost any van, from Class B to Class A, from trailers to fifth wheels.
Ultra-thin design for low wind resistance:
At only 0.5 in (12 mm), this slimline panel significantly reduces wind resistance by more than 60% when you're on the road, effectively improving fuel efficiency and saving on fuel costs. Our RVMax solar panel is almost 1 inch (23 mm) slimmer than traditional models.
Modular Design
EcoFlow 130W RVMax Rigid Solar Panel features an innovative modular design, delivering up to 130W power, 50V, and 3A current output, and connects up to 10 panels within a safe range. Works seamlessly with various power stations.
50v High Voltage Design
Safe and Simplified LFB-40 Connection
State-of-the-Art N-Type TOPCon Solar Cell
Maximum Power, Extended Lifespan
With N-Type TOPCon technology, achieve up to 25% conversion efficiency.
Coated with Protective Lamination & Tempered Glass
Engineered to Withstand the Elements
Built for the road ahead, TOPCon solar cells with ultra-slim 2 mm tempered glass maximize light transmission while providing solid protection against debris, storms, or hail during your journey. RVMax's reinforced corners help prevent impact damage and hidden cracks common in standard panels. Complete with an IP68 rating and the waterproof LFB-40 connector, this panel delivers reliable power through rain, dust, and challenging weather conditions.
Universally Compatible Solar Cable
Plug and Play with Your Power System
Easily connect to third-party solar systems using the included photovoltaic connector (MC4 compatible)⁴. Safely charge your power systems and portable power stations with XT60 connectors, featuring waterproof, anti-leak technology that's touch-safe and reliable.
Adapts to Various RV Power Systems
Power Kits
EcoFlow DELTA & RIVER Series
Third-party portable power stations
Other RV power system
What's in the Box
Rated Power
130W (±3W)
Dimension(mm)
1345x524mm(12mm)
Net Weight(kg)
3.5kg
Waterproof & Dustproof Rating
Cell Type & Efficiency
topcon 25%
Open-Circuit Voltage
51V
Optimal Operating Voltage
43V
Short Circuit Current
3.2A
-0.3%/C
5 years
What types of vehicles is this solar panel suitable for?
It is suitable for installation on the roofs of Class B Vans, Class C vehicles, and trailers.
Do solar panels need extra controllers or inverters?
You should choose the right controller or inverter based on your specific usage to ensure efficient storage and use of electricity.
How do you connect this solar panel?
This solar panel features a high-voltage design and uses an LFB-40 interface. It can be connected in series to save on wiring.
What is the LFB-40 interface?
The LFB-40 interface is a common DC power output connector used for solar panels. It primarily facilitates power transmission between portable solar power generation equipment and devices like charging controllers, energy storage units, and power banks.
What are the features of the LFB-40 interface?
This interface supports a maximum current of 40A, meeting the standard 30A current capacity. It can reliably handle high currents, preventing overheating or damage. It can be connected in series, allowing up to 10 130W solar panels to be linked together. Additionally, it has a locking mechanism to ensure the solar panel remains secure and does not detach due to vibrations when installed on a vehicle.
How should solar panels be cleaned and maintained?
Regularly clean the panels with clean water or a damp cloth to prevent dust from reducing their efficiency. Avoid using hard objects to scratch the surface to prevent damage. Annually check the wire connections to make sure they are secure, as poor connections can affect charging.
Can solar panels generate electricity on cloudy days or at night?
Solar panels require sunlight to generate electricity. They can still produce a small amount of power on cloudy days, but with reduced efficiency. At night or in extreme weather conditions, their power generation capacity will significantly decrease or stop, so using energy storage equipment is recommended.
Can solar panels generate electricity during winter?
Yes, but their efficiency will be lower. Winter has shorter daylight hours, and low temperatures can affect the performance of the batteries. It is advisable to regularly check if the solar panels are covered by snow during winter to maintain good power generation capacity.
Can solar panels handle high temperatures?
Typically, they can endure temperatures ranging from -40°C to 85°C, though extended exposure to high heat might reduce their efficiency.
Will adding solar panels make a vehicle heavier?
Solar panels are quite light, with each panel weighing around 5.6 kg, so they generally don't add much weight to the vehicle.
Thanks for sharing!
Select your language
