EcoFlow Smart Generator 3000 (Dual Fuel) | EcoFlow CA
EcoFlow Smart Generator 3000 (Dual Fuel) EcoFlow Smart Generator 3000 (Dual Fuel) EcoFlow Smart Generator 3000 (Dual Fuel)
$1,049.00 CAD
Member Exclusive Product
Regular price $1,049.00 CAD
Sale price $1,049.00 CAD Regular price $1,099.00
-$50
Note: The "automatic start-stop" function of Smart Generator 3000 (Dual Fuiel) is only compatible with DELTA 3, DELTA 3 Classic and DELTA 3 Plus.
Dual Fuel: gasoline and LPG
  • 20kWh capacity with standard LPG tank for worry-free backup power
  • Remotely control and real-time monitor using the app
  • 5 ways to start
  • 5 security alerts
  • Seamlessly integrate your LPG power backup
  • Designed for easy maintenance, and as quiet as 69 dB at a distance of 23 ft.
$1,049 CAD $1,099 -$50
The most accessible and portable home standby generator
Unlock unmatched power and reliability with the EcoFlow Smart Generator and DELTA 3 Plus hybrid setup. With max. 3000W AC fast charging, enjoy flexible and convenient backup power, perfect for a wide range of scenarios — from essential home standby backup to on-the-go charging.
Introducing the most accessible home standby power solution to complement your DELTA 3 Plus. The EcoFlow Smart Generator 3000 powers your most essential home appliances with dual-fuel support and customizable auto-start/stop modes. It's more efficient, intuitive, and reliable than ever.
Mini Home Standby Generator
Effortless Home Backup System with DELTA 3 Plus
Portable for Small Businesses
Build your first home standby power system with ease, including a generator shed for added protection.
Recharge your batteries while simultaneously powering other essential AC appliances through the AC outlets.
Keep your electronics powered anywhere by plugging them into the two AC outlets on the generator.
Dual Fuel for Double Peace of Mind
Rest assured with both LPG and gasoline at hand, providing easy access to backup power and eliminating worries about fuel shortages during emergencies.
Rest easy knowing that LPG and gasoline are readily accessible, ensuring you can quickly obtain fuel for backup power and alleviating concerns about fuel shortages during emergencies.
Gasoline Power
LPG Power
With a 2000W-3000W*¹ output and a 4L gasoline tank, generate up to 6.6kWh. A full tank runs for up to 9 hours at 25% load or 3.3 hours at full load.
Simply plug in a 20lb propone tank and allow you access to a 20kWh power, secured and keep your family a whole day of cozy life in a outage. A 20 lb tank provides up to 11 hours at full load.
Power Backup Made Smart and Simple
With four intelligent self-start modes, when paired with the EcoFlow DELTA 3 Plus and DELTA 3, power backup is easier than ever.
With four intelligent self-start modes, when paired with the EcoFlow DELTA 3 Plus, power backup is easier than ever.
With four intelligent self-starting backup modes (when paired with EcoFlow DELTA 3 Plus and DELTA 3), power backup has never been easier.
Customizable start/stop
Scheduled Automatic Start
PV-priority mode
The Smart Generator auto-starts when power consumption from the battery reaches a set level, ensuring uninterrupted power, without the need to get up in the middle of the night to manually reset it.
The Scheduled Automatic Start function allows you to set up tasks in the app to automatically start and stop your smart generator at pre-set times. This feature provides convenience and ensures your generator is ready when needed, whether for backup power during peak usage hours or maintaining your devices and appliances without manual intervention.
Prioritize PV panel charging for quieter, eco-friendly operation. Need extra power? Switch to the PV and Smart Generator combo with a tap on the EcoFlow app.
Cleaner, Greener, Quieter Power
The Smart Generator 3000 is designed for eco-friendly performance, cutting CO emissions and operating at a quiet 69 dB—similar to a dishwasher—offering power with minimal environmental impact and disruption.
Effortless Control at Your Fingertips
With the EcoFlow app, monitor and manage energy usage and equipment operation remotely. Receive real-time alerts for CO levels, temperature fluctuations, and more to ensure safety. Stay on top of maintenance with fault notifications and service prompts for hassle-free upkeep.
Multiple Start/Stop Options for Seamless Operation
The EcoFlow Smart Generator 3000 (Dual Fuel) offers intelligent, versatile start/stop methods to suit any scenario, making operation easier than ever.
5 Quick Start Methods
① Manual pulling cord start
② Electric button start
③ Customizable Start by Portable Power Station
④ App start (Bluetooth/Wi-Fi)
⑤ Scheduled automatic start.
Tip: The auto start/stop function is currently supported when workiring with EcoFlow DELTA 3 Power Station or EcoFlow DELTA 3 Plus Power Station. Compatibility informattion may be updated. Please check the official website for the latest details.
6 Shutdown Methods
① Knob switch off
② One-click shutdown (electric button)
③ automatic shutdown
④ Scheduled-time shutdown
⑤ Low output shutdown*
⑥ App-controlled shutdown.
*When matched with a third-party portable power station, it automatically shuts down after the power station is fully charged, detecting a drop in output power.
Stay Protected with Real-Time Alerts
Receive 5 key safety notifications directly via the EcoFlow app, keeping you informed whether you're indoors or away. All features trigger automatic shutdowns for your safety (except fuel alerts).
Generator Specs
21.8kg
480*300*455mm
Type
Inverter Generator
Frequency
60Hz
Rated Voltage
120V
Rated Power
2000W with Gasoline, 1800W with LPG (3000W Peak Output with X-Boost Tech)
DC5521 Input
8-26V, 15W Max
Engine Specs
Displacement
98cc
Type
Four-stroke
Fuel Type
Unleaded gasoline/LPG
Fuel Tank Capacity
4L
Engine Oil Capacity
400mL
Noise Level (at 7m distance)
69 dB (full load)
Continuous Working Time (Gas)
3.3hr (full load), 9hr(1/4 load)
What type of engine does EcoFlow Smart Generator 3000 (Dual Fuel) have?
Single cylinder, four-stroke, forced-air cooling, overhead valve.
What are the battery specifications for EcoFlow Smart Generator 3000 (Dual Fuel)?
The capacity is 19.2Wh, and the specifications are 12.8V, 1500mAh.
What type of oil is recommended for EcoFlow Smart Generator 3000 (Dual Fuel)?
Recommended oil: SAE SJ 10W-40Recommended oil grade: API SJ or higherOil capacity: 400 mlRefer to the oil dipstick mark in the manual for the correct amount to add. Do not overfill, as this can damage the engine.
What is Eco mode?
The generator automatically adjusts the engine speed based on the power output level to reduce fuel consumption and noise.
What types of gas fuels does EcoFlow Smart Generator 3000 (Dual Fuel) support? Can it use butane, natural gas, or hydrogen?
The EPA version only supports gasoline and LPG.
Can I use diesel? Can I use 92/95/98 gasoline?
Only unleaded gasoline can be used. 92/95/98 and E10 are compatible, while diesel is not.
Can LPG and gasoline be used simultaneously?
No, they are mutually exclusive. When using LPG or gasoline, the engine switch must be turned to "MANUAL". LPG has the highest priority; once the LPG hose is connected, the generator automatically switches to LPG fuel, stopping the use of gasoline.
How many ways are there to start EcoFlow Smart Generator 3000 (Dual Fuel)?
There are 4 ways: manual pull start, one-button start, self-start, and app start.
Which models are compatible with EcoFlow Smart Generator 3000 (Dual Fuel)?
The EcoFlow Smart Generator 3000 (Dual Fuel) does not have an XT150 port. It has two AC output ports and is compatible with all power stations through AC connection.
Is the generator's cylinder a carburetor or direct injection?
The generator's cylinder uses a carburetor. The carburetor mixes fuel and air in the optimal ratio before it enters the combustion chamber, maximizing conversion efficiency.
Select your language
Unlock Exclusive Member Savings
Member Price
$3,358.00
Original Price
$3,598.00
