EcoFlow DELTA 3 Plus Portable Power Station | EcoFlow CA - (Members-only) DELTA 3 Plus + 220W Portable Solar Panel
EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station EcoFlow DELTA 3 Plus Portable Power Station
$1,106.00 CAD
Member Exclusive Product
Regular price $1,106.00 CAD
Sale price $1,106.00 CAD Regular price $1,998.00
-$892
Cyber Week Extended — The Deals Go On!
Free 45W Panel with Orders $500+
Free 160W Panel with Orders $2,000+
Ends in:
During the Promotion Period (Dec 2-Dec 8, PST), customers who purchase from ca.ecoflow.com will receive a free gift based on their order value:
1. Spend $500 or more in a single order (calculated before tax) to receive an EcoFlow 45W Portable Solar Panel (valued at $99 CAD).
2. Spend $2,000 or more in a single order (calculated before tax) to receive an EcoFlow 160W Bifacial Portable Solar Panel (valued at $279 CAD).
* This promotion does not apply to flash sale items, recommended accessories, Power Kits, gift cards, app-only products, member-priced items, DELTA Pro Ultra X Series, Smart Home Panel 3, Smart Gateway, Automatic Transfer Switch, DELTA Pro Series.
* Each order is eligible for one free gift only.
•1-5kWh expandable with DELTA 3 Extra Battery, DELTA 2 Extra Battery or DELTA 2 Max Extra Battery (with Alternator Charger XT150 Output Cable), DELTA Pro 3 Extra Battery (with Alternator Charger XT150 Output Cable & Smart Generator Adapter).
•1800W AC output, 2200W (surge 3600W) with X-Boost
•5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
•5-year warranty
$549 CAD $699 CAD
$229 CAD $899 CAD
25% Conversion Rate | IP68
EcoFlow DELTA 3 Series Waterproof Bag
$89 CAD
Subscribe DELTA 3 Plus for latest updates
$1,106 CAD $1,998 -$892
DELTA 3 Series
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-2600W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Outdoors
RV
Home backup
Professional work
30 dB Ultra-quiet Operation.
*EcoFlow DELTA 3 Series power stations are compatible with the following Extra Battery models:DELTA 3, DELTA 2 Max, DELTA 2 (with Alternator Charger XT150 Output Cable), DELTA Pro 3 (with Alternator Charger XT150 Output Cable & Smart Generator Adapter).
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Net Weight (kg)
≤12.5kg
1024 Wh
Extra Battery
Supports DELTA 3, DELTA 2 Max, DELTA 2 (with Alternator Charger XT150 Output Cable), DELTA Pro 3 (with Alternator Charger XT150 Output Cable & Smart Generator Adapter).
Total Output Ports
13
2600W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
Select your language
Unlock Exclusive Member Savings
Member Price
$3,358.00
Original Price
$3,598.00
