EcoFlow DELTA 2 + DELTA 2 Smart Extra Battery - DELTA 2 + Smart Extra Battery - EcoFlow CA
EcoFlow CA
EcoFlow DELTA 2 + DELTA 2 Smart Extra Battery EcoFlow DELTA 2 + DELTA 2 Smart Extra Battery
$2,199.00 CAD
Ask a question
Regular price $2,199.00 CAD
Sale price $2,199.00 CAD Regular price $2,398.00
-$199
  • Expandable capacity - 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
  • Huge AC output - 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
  • 7x Faster AC charging - X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input.
  • Or go green without sacrificing speed - Plug in portable solar panels and get up to 500W input to charge from anywhere in as fast as 3 hours.
  • Built to last 6x longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
  • Control from anywhere - Use the EcoFlow app to control your DELTA 2 from anywhere using Wi-Fi. Link with Bluetooth when off-grid. Either way, you can check charging data, customize settings and adjust the charging speed with ease.
  • 5-year warranty Unlock an extended 5-year warranty for worry-free experience.
Click here to learn more about DELTA Max Smart Extra Battery.
    $2,199 CAD $2,398 -$199
