Buy EcoFlow 220W Bifacial Portable Solar Panel
EcoFlow NextGen 220W Bifacial Portable Solar Panel EcoFlow NextGen 220W Bifacial Portable Solar Panel EcoFlow NextGen 220W Bifacial Portable Solar Panel
$999.00 CAD
Regular price $999.00 CAD
Sale price $999.00 CAD Regular price $1,798.00
-$799
Two in one EcoFlow’s 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Tempered glass. Built to last The thin, one-piece tempered glass design makes it five times tougher than comparable panels, it can withstand heat up to 300°F too. Safe to say it can withstand the elements.
Compact. Portable It’s a portable solar panel designed from the ground up to be compact. 10% smaller than comparable 220W panels, it saves space with thinner tempered glass, and less surface area required for the same input.
More than a carry case It comes with its own carry case so you can take it anywhere. Once you arrive at your destination, simply unfold it and use it as a kickstand to get your sun exposure just right.
Waterproof We’ve raised the bar with this panel. It's completely water and dust-tight. Rain, wind or shine, your panel is safe with an IP68 waterproof rating.
Buy 2 get 10% off
- Buy 2 accessories and get 10% off automatically at checkout.
- View all accessory offers
Learn more
Accessory Discount (Dec 9-Dec 26, PST):
  1. Customers who purchase two (2) eligible accessories in a single order will receive a ten percent (10%) discount on the subtotal of the eligible accessories only.
  2. This offer is not applicable to Flash Sale items, recommended accessories, member-only products, Power Kits, gift cards, app-only products, DELTA Pro Ultra X Series, Smart Home Panel 3, Automatic Transfer Switch, DELTA 3 1000 Air Series, New RAPID Mag Series.
  3. The discount cannot be combined with any other promotions, offers, or coupons.
  4. EcoFlow reserves the right to amend, suspend, or terminate this offer at any time without prior notice.
$999 CAD $1,798 -$799
MC4 to XT60i Charging Cable
Protection Bag
Protection Bag
Quiet Start Guide & Safety Instructions & Warranty Card
Rated Power
220W(±5W) Front/175W Rear
Cell Type
TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
Approx. 15.4lb (7.0kg)
Unfolded: 24.2*84.8*1.0 in /615 x 2155 x 25mm
Folded: 24.2*23.2*1.3 in /615 x 590 x 32mm
Connector Type
MC4
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Solar Panel Weight
15.4 lb (7.0kg)
Waterproof & Dustproof
Select your language
