Buy EcoFlow 220W Bifacial Portable Solar Panel
EcoFlow NextGen 220W Bifacial Portable Solar Panel EcoFlow NextGen 220W Bifacial Portable Solar Panel EcoFlow NextGen 220W Bifacial Portable Solar Panel
$429.00 CAD
Regular price $429.00 CAD
Sale price $429.00 CAD Regular price $899.00
-$470
Two in one EcoFlow’s 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 155W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Tempered glass. Built to last The thin, one-piece tempered glass design makes it five times tougher than comparable panels, it can withstand heat up to 300°F too. Safe to say it can withstand the elements.
Compact. Portable It’s a portable solar panel designed from the ground up to be compact. 10% smaller than comparable 220W panels, it saves space with thinner tempered glass, and less surface area required for the same input.
More than a carry case It comes with its own carry case so you can take it anywhere. Once you arrive at your destination, simply unfold it and use it as a kickstand to get your sun exposure just right.
Waterproof We’ve raised the bar with this panel. It's completely water and dust-tight. Rain, wind or shine, your panel is safe with an IP68 waterproof rating.
$429 CAD $899 -$470
MC4 to XT60i Charging Cable
Protection Bag
Protection Bag
Quiet Start Guide & Safety Instructions & Warranty Card
Rated Power
220W(±5W) Front/175W Rear
Cell Type
TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
Approx. 15.4lb (7.0kg)
Unfolded: 24.2*84.8*1.0 in /615 x 2155 x 25mm
Folded: 24.2*23.2*1.3 in /615 x 590 x 32mm
Connector Type
MC4
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Solar Panel Weight
15.4 lb (7.0kg)
Waterproof & Dustproof
Select your language
Turn on Growave
