100% secure shopping
Reliable warranty
Free shipping
EcoFlow RIVER + 110W Solar Panel
Regular price
$1,197.00
Sale
$1,197.00
Regular price
$1,449.00
Sold out
per
As low as $88/mo or 0% APR.
NUMBER OF SOLAR PANEL
  • 1
  • 2
View cart
TO DOUBLE THE CAPACITY OF RIVER,CLICK HERE RIVER EXTRA BATTERY
  •  3 x 600W AC OUTLETS AND 288Wh CAPACITY The EcoFlow RIVER can power up to 10 devices simultaneously. With 3 pure sine wave AC outlets, the EcoFlow RIVER can power some devices up to 1800W with the X-Boost mode on. With a capacity of 288Wh, the EcoFlow RIVER provides enough juice to run essential devices for hours, depending on the actual output.
  • RECHARGE FROM 0% TO 80% WITHIN 1 HOUR With EcoFlow’s patented X-Stream Technology, the smart inverter enables a fast rechargeability that takes less than 1 hour to charge from 0% to 80%, and it gets fully charged in 1.6 hours. You can switch to a quieter charging condition by turning on the “Quiet Charging” status on the APP.
  • COMPATIBLE WITH 80% HOME APPLIANCES The X-Boost Technology’s advanced built-in algorithm enables most heavy-duty kitchen appliances and tools (up to 1800W) to operate. With X-Boost, EcoFlow RIVER can power 80% of essential home appliances and devices, especially those within 1200W for a better using experience. The discharging rates and X-Boost mode can be monitored and controlled through the EcoFlow APP.
  • FIT YOUR NEEDS, NOW AND LATER Double the capacity from 288Wh to 576Wh with an Extra Battery, the modular design of EcoFlow RIVER, is the power that grows with your needs. Designed for mobility, the 11 lbs solid yet lightweight EcoFlow RIVER is slightly larger than a toaster, which is perfect to take out. You can easily double the capacity of the EcoFlow RIVER from 288Wh to 576Wh by integrating with an Extra Battery.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
EcoFlow RIVER Portable Power Station
Compact and portable, the EcoFlow RIVER series is an ideal recreational power that provides you the accessibility to handy wall outlets. The EcoFlow RIVER series is the perfect companion for camping, over-landing, tailgating, boating, etc. Feel free to attach and detach the Extra Battery to meet your needs.
  • 11 Lbs lightweight and portable power station;
  • Support 80% of essential devices with X-Boost mode on;
  • Fast AC recharge within 1.6 hours;
  • Handy Control with EcoFlow App;
  • Modularized capacity to grow with your needs, from 288Wh to 576Wh with Extra Battery
X-Boost Smart Algorithm
The EcoFlow X-Boost technology gives you the ability to use the 600W inverter to power essential devices like kitchen appliances and tools up to 1800W. This unique technology is perfect for outdoor adventures when you need to power your favorite devices on the go. Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances. Use X-Boost with devices below 1200W for the best product experience.
Faster Recharging Speed
The EcoFlow’s X-Stream technology redefines the power station’s speed of chargeability, eliminating the bulky adapters. With the built-in smart inverter, EcoFlow RIVER delivers a fast recharging performance. Only need to plug into a regular wall outlet for 1.6 hours, you will have a 100% charged unit.
Power that Grows with You
With the modular design and the Extra Battery, you can easily expand the capacity of EcoFlow RIVER from 288Wh to 576Wh.
EcoFlow RIVER : Lightweight and portable, perfect for a weekend trip or tailgating events;
EcoFlow RIVER + Extra Battery: Compact and reliable for outdoor adventures or RV/van usage.
Power 10 Devices Simultaneously
EcoFlow RIVER fits many types of the ports you’ll need to charge all your devices. The 100W USB-C is perfect for charging laptops while the full sine wave AC outlets give you more flexibility in charging heavy duty devices. With the informative EcoFlow APP, you can control and monitor the unit on your hands.
Sustainable Solar Charging
The smart MPPT inside of the EcoFlow RIVER enables it to recharge quickly through the solar power at a 200W maximum loading scale. With two 110W solar panels (IP67 waterproof) connected in parallel under a direct, perfect sunlight condition, the EcoFlow RIVER can be fully charged from 1.6 to 3 hours, giving you the freedom to enjoy clean, sustainable power from nature.
Compact and Portable
With the rugged easy-to-carry handle, the 11lbs EcoFlow RIVER is perfect for outdoorsy use. Slightly larger than a toaster, it can easily fit in the trunk of a minivan, or anywhere in the house whenever you need an AC power source. You can always be prepared for the next adventures, anytime, with this reliable, portable power station.
Power a Wide Range of Devices
The RIVER comes with three AC outlets. (Note that the total rated wattage of the three AC outlets is 600W (surge 1200W)). With a built-in 600W inverter, the RIVER can power devices up to 1800W with the X-Boost mode on. This provides support for a wide range of essential devices such as a fridge, TV, laptop, hairdryer, and more.
Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
EcoFlow 110W Solar Panel
EcoFlow110W Solar Panel High Compatibility
How to Chain EcoFlow 110W Solar Panels
Adjust the Kickstand of EcoFlow 110W Solar Panel
EcoFlow Solar Panel Waterprrof Design
Solar Panel Connection Tutorial
