100% secure shopping
Reliable warranty
Free shipping
EcoFlow RIVER Max + 110W Solar Panel
Regular price
$1,547.00
Sale
$1,547.00
Regular price
$1,799.00
Sold out
per
As low as $88/mo or 0% APR.
NUMBER OF SOLAR PANEL
  • 1
  • 2
View cart
  • POWER WHEREVER YOU GO: Portable solar power generator + Extra Battery that gives you reliable power for outdoor adventures, indoor use, and emergency situations.
  • RECHARGE FROM 0-80% WITHIN 1 HOUR: EcoFlow X-Stream Charge technology recharges the power station from 0-80% within one hour, which is one of the fastest recharging rates on the market. Quiet Charging can be enabled from the EcoFlow app.
  • POWER UP TO 10 DEVICES SIMULTANEOUSLY: EcoFlow’s X-Boost technology allows you to power some devices up to 1800W, which lets you power up to 80% of essential devices like kitchen appliances, and DIY tools.
  • MODULAR DESIGN: The unique modular design gives you the freedom to adjust the power and portability of the EcoFlow RIVER Max within seconds. The Extra Battery doubles the capacity from 288Wh to 576Wh during situations when you need more power. You can also detach the Extra Battery easily for more portability during traveling, outdoor adventures, or any application where you need to power devices on the go.
  • 3 x 600W AC OUTLETS AND 576Wh CAPACITY: The EcoFlow RIVER Max has 3 AC outlets and a capacity of 576Wh, providing multiple users with incredible power for all of your favorite devices.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
EcoFlow RIVER MAX
The EcoFlow RIVER Max features the RIVER power station plus an Extra Battery, which doubles up the battery capacity and offers you reliable, portable, and easy-to-access power wherever you are.
X-Boost Technology
The EcoFlow X-Boost technology gives you the ability to use the 600W inverter to power essential devices like kitchen appliances and tools up to 1800W. This unique technology is perfect for outdoor adventures when you need to power your favorite devices on the go. Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances. Use X-Boost with devices below 1200W for the best product experience.
X-Stream Charging Technology
EcoFlow’s X-Stream technology offers one of the fastest recharging rates for a power station on the market. With the built-in smart inverter, EcoFlow RIVER Max can recharge from 0-80% within 1 hour, achieving a full charge in just 1.6 hours.
Modular Design + Extra Battery
The EcoFlow RIVER Max features a compact, modular design that allows you to attach an extra battery to double the capacity of the device from 288Wh to 576Wh. Alternatively, you can detach the Extra Battery to make the device more portable. Whether you’re with family or going on a solo road trip, the modular design gives you all the freedom to customize your power options however you like.
Power 10 Devices Simultaneously
EcoFlow RIVER Max fits many types of the ports you’ll need to charge all your devices. The 100W USB-C is perfect for charging laptops while the full sine wave AC outlets give you more flexibility in charging heavy duty devices. With the informative EcoFlow APP, you can control and monitor the unit on your hands.
Efficient Solar Power
The EcoFlow RIVER Max is also compatible with the EF Solar Panels, which provide you with a way to generate clean, reliable solar power on the go. Two 110W Solar Panels can be connected in parallel to charge the EcoFlow RIVER Max from 3-6 hours.
Easy-to-Carry Handle
Introducing the future of portable power stations. EcoFlow RIVER Max weighs 17lbs, is exceptionally durable, and features an easy-to-carry handle. This incredibly portable power station can be taken around wherever you go, whether that be on your car trunk, coffee table, or the great outdoors. It’s that easy.
Power a Wide Range of Devices
The RIVER Max comes with three AC outlets. (Note that the total rated wattage of the three AC outlets is 600W (surge 1200W)). With a built-in 600W inverter, the RIVER Max can power devices up to 1800W with the X-Boost mode on. This provides support for a wide range of essential devices such as a fridge, TV, laptop, hairdryer, and more.
Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
EcoFlow 110W Solar Panel
EcoFlow110W Solar Panel High Compatibility
How to Chain EcoFlow 110W Solar Panels
Adjust the Kickstand of EcoFlow 110W Solar Panel
EcoFlow Solar Panel Waterprrof Design
Solar Panel Connection Tutorial
