EcoFlow DELTA 3 Series Portable Power Station | EcoFlow CA - DELTA 3 Plus + 800W Alternator Charger - EcoFlow CA
EcoFlow CA
EcoFlow DELTA 3 Series Portable Power Station EcoFlow DELTA 3 Series Portable Power Station EcoFlow DELTA 3 Series Portable Power Station
$1,099.00 CAD
Regular price $1,099.00 CAD
Sale price $1,099.00 CAD Regular price $1,798.00
-$699
Up to EcoCredits for cash deduction. Log in
DELTA 3 Plus is currently out of stock, but don't miss out! Our DELTA 2 is in stock.
•1-5kWh expandable with DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, DELTA 2 Extra Battery or DELTA 2 Max Extra Battery.
•1800W AC output, 2200W (surge 3600W) with X-Boost
•5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
•5-year warranty
$1,099 CAD $1,798 -$699
DELTA 3 Series
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Home backup
Outdoors
RV
Professional work
30 dB Ultra-quiet Operation.
*EcoFlow DELTA 3 Series are compatible with Extra Battery of DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Net Weight (kg)
≤12.5kg
1024 Wh
Extra Battery
Support DELTA 2 EB, DELTA 2 Max EB, DELTA Pro 3 EB, and DELTA 3 EB (Up to 5kWh)
Total Output Ports
13
2600W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
