Ready to install on any surface
Pre-Drilled Slots for Secure Mounting
With pre-cut holes along the panel's perimeter, the 175W rigid panel is ready to mount on your van or off-grid build. Pair with the Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
Just plug and play with your power system
Universally Compatible Solar Cable
Using an all-inclusive solar connector, connect with any existing third-party solar system. Charge 48V power systems and portable power stations with single or multiple panels.
How to choose your solar panel
What‘s In The Box
Rated Power
175W (+/-3W)
Cell Type
N Type TOPCon Monocrystalline Silicon
Efficiency Rating
Up to 25%
Weight (Solar Panel)
20.5 lb (9.3 kg)
46.3×30×1.2 in (1176 x 762 x 30 mm)
Connector Type
Photovoltaic Connectors (Adaptable to MC4 Connectors)
Warranty (US)
5 Years
Waterproof & Dustproof Rating
Short Circuit Current
8.3 A
Open Circuit Voltage
25.5 V
Maximum Operating Voltage
22.3V
7.85A
