Buy EcoFlow 110W Portable Solar Panel
EcoFlow 110W Portable Solar Panel EcoFlow 110W Portable Solar Panel
Regular price $509.00 CAD
Sale price $509.00 CAD Regular price $998.00
-$489
• Portable and lightweight
• Up to 23% conversion rate
• Self-supporting
• One-piece folding design
• The solar to XT60 charging cable is included in EcoFlow portable solar panels
    $509 CAD $998 -$489
    ⚠️ Firmware Update Required for 1T2 Accessory
    To use the 1T2 accessory properly, all compatible main units must be updated to the latest firmware version. Without the required firmware, you may experience operational issues.
    Required firmware versions:
    • DELTA 3 Max Plus: v7.80.98.44 or above
    • DELTA 3 Ultra Plus: v7.80.98.46 or above
    If you have not received the firmware update, please contact our customer support team to have it pushed to your device. To complete the upgrade, connect each EB to the main unit separately — the process requires two separate upgrades. Once both upgrades are complete, the 1T2 accessory will function normally.
    Get off the grid with EcoFlow's 110W Solar Panel for renewable energy wherever you end up.
    Universal
    Seamless
    Foldable
    Portable
    Powerfully portable
    With an industry-leading 23% conversion rate, it's far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
    Self-supportable
    Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
    Waterproof & Durable
    Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That's an all-weather ready panel designed to stand the test of time.
    It comes with a carry case too.
    On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
    Title
    RIVER mini
    RIVER
    RIVER Max
    RIVER Max Plus
    RIVER Plus
    RIVER Pro
    DELTA mini
    DELTA 1000
    DELTA 1300
    RIVER
    RIVER Max
    RIVER Pro
    RIVER Plus
    RIVER Max Plus
    DELTA mini
    DELTA 1000
    DELTA 1300
    DELTA mini
    DELTA Max(1600)
    DELTA Max(2000)
    1.110W Solar Panel 2.110W Solar Panel Bag 3.110W Solar Panel User Manual
    Compare The Models
    110W Solar Panel
    Rated Power: 110 Watts
    Unfolded : 62.5 x 20.2 x 1.0 in
    Efficiency : 21-22%
    Warranty : 12 Months
    $499
    160W Solar Panel
    Rated Power: 160 Watts
    Unfolded : 61.8 x 26.8 x 1.0 in
    Efficiency : 21-22%
    $599
    Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
    Yes, if the only thing between it and the sun is transparent, but it won't charge as well compared to being outside. You can compare the difference by looking at the input section of your power station's LCD screen.
    Unfolded Dimensions
    20.2*62.5*0.8 in /178.5*42.0*2.5cm
    Folded Dimensions
    20.2*16.5*0.8 in/42.0 x 48.0 x 2.5cm
    Weight
    8.8lb (4kg)
    12 months
    Rated Power
    110W (±5W)
    Efficiency
    22%–23%
    Connector Type
    Solar Connector
    Open Circuit Voltage
    21.8V (Vmp 18.4V)
    Short Circuit Current
    6.5A (Imp 6.0A)
    Cell Type
    Monocrystalline Silicon
    Operating & Storage Temperature
    −4°F to 185°F
    Folded Dimensions
    Payment options through Affirm Canada Holdings Ltd. (“Affirm”). Your rate will be 0–31.99% APR (where available and subject to provincial regulatory limitations). APR offered is based on creditworthiness and subject to an eligibility check. Not all customers will be eligible for 0% APR. Payment options depend on your purchase amount, may vary by merchant, and may not be available in all provinces/territories. Actual payment option terms will be shown at checkout. A down payment (or a payment due today) may be required. Affirm accepts debit cards and PAD as forms of repayment on payment options. Select payment options may be eligible for repayment in the form of credit cards. Please review the terms and conditions of your credit card when using it as a form of repayment. Sample payment options may be: a $800 purchase could be split into 12 monthly payments of $72.21 at 15% APR, or 4 interest-free payments of $200 every 2 weeks. For more information, please seehttps://www.affirm.com/en-ca/how-it-works.
    Select your language
